Spent some time in the shop doing some machining , made up my ring-sprockets for my clutches , welded them to the clutch bells and linked them with some chain.
I hope it works , but it sure looks cool kinda like the primary drive on some choppers.
Cutting out the centres of my sprockets.
Fitting on the clutches.
All welded up and test fitted on engines.
Made up my rear brake rotor mount , turned the teeth of a sprocket to make a flange to bolt the rotor to.
Tomorow I will take a look at the rear brake caliper mount and master cylinder , I will have to think about footpegs too because it will need a brake lever.
Rob.
