I recently bought a bike. It came today in the mail and this part was inside. I'm not sure what it is, but I'm nearly certain it's not a mini bike part.
It's about 22" long from end to end, the straight pipe is about 19-1/4" long and is 1" OD. The end with a fitting is 2" OD and 1-3/4" ID and has teeth on the end so it can lock into whatever it connects to. It has a pressure release ball valve inside. It gives way after about 10-15 lbs of pressure, maybe more. The only markings on it are BUD/S 316 0296 and 0487. I've searched online but I'm not sure. Either gas or water pipe of some sort.
I figured that you guys, an assortment of tradesmen would most likely know what it was from, or what it was used for. Any help would be appreciated
