help.
  1. S
    need help.
    what is it.
  2. minibikes4life
    reo model f help.
    having trouble getting the bowl to come off the carburetor, i assume its just gummed up around the bowl itself, any recommendations?
  3. Wideopenthrottle
    Gocart identity, resto help.
    so, i picked up this gocart for free, it looks like an old racer youd see on t.v. on dirt i was wondering what it is, the engine goes beside the cart, front suspension, im guessing rear, seat suspension ill post up some pics tomorrow but if u have any ideas lemee know. Edit : Its now...
  4. cxbra
    Sticky clutch help.
    I finally got my mini started today :thumbsup: but the clutch is stuck engaged and it pulls hard at idle.. At first I thought it must be too much throttle somehow (even though I saw the carb butterfly was closed) but then I realized the clutch was stuck. What could I do without pulling off the...
  5. PAPSTISY
    Rookie question. Please help.
    I have a H50 and I'm wondering how can you tell if your motor has the Alternator that is needed for lights. I can peek behind the wheel and see some type of coil but I don't want to take everything apart. The engine has a wire coming out from behind the metal wheel and is attached to the...
  6. R
    Predator 212cc won't just idle. please help.
    I just picked up the predator 6.5hp and got it all set up in the bike. Stared up like a dream but the clutch seems to be engaging before I'm able to get the choke to a point where the throttle will work. once it's going though it takes off like a rocket but there's no real control. It just keeps...
  7. N
    CAT Mini bike found , need help.
    New member here, I've looked at all the images I can find and have not seen this model. The paint color is gold and the seat is white. The first ones don't include the NOS gas tank I bought at Winber today. Great time by the way. Thanks in advance.
  8. minibikes4life
    H35 spring installation help.
    I lack a proper spring compressor, and was wondering if anyone had any tricks or ideas on how i could install my springs without one?
  9. J
    need help.
    I finally got around the installing my Robin engine in my db30, fits perfect. But my throttle set up runs sideways to the length of the bike. So I need some type of right hand (90 deg.) throttle set up. Anyhone have any Ideas ? Thanks, David.
  10. M
    Need help.
    Hi i'm from Quebec , Canada . I found this forum last year .I was looking for rupp ruppster and i found one this week but...... The buggy is in kinsman Ohio and i need to ship it to Malone NEW York (i will take it from there to pass the boarder) I need help do semeone know a carier that can...
  11. M
    New toy, need help.
    As you can see I'm new here, my intro post can be seen here:http://www.oldminibikes.com/forum/off-topic-discussion/32490-hello-all.html So I came across this cool little bike going through Craigslist. Came with a tired barely working unstable tecumseh flat-head 3.5 or 5 Hp engine. Didnt even...
  12. 1
    Looking for parts, help.
    I'm looking for a set of wheels 6" and sprocket for my frame so I can make my mini bike frame into a roller. New or used is fine. Any help finding them would be great. This is my first time building a mini, hope I posted this in the right area. Thanks!
  13. dirt
    h 35 header or pipe help.
    hi i have been looking on the internet. i want a pipe for my H 35 mini bike. it has a round snuff can exaust . i want a 15 " 3/4" pipe. does anyone have a header on a stock 3-4 HP ? thanks
  14. 1stlegendtx
    Taco information Help.
    Is there anyone out there who has some Taco print info that is not what can be found at the Steens site? I know the Sensires book has a couple of differant pictures of the brake and a very limited parts list. It seems like there must be more some where.
  15. W
    HM100 10hp...Crankshaft help.
    ok so i got an amazing 10hp tech. motor of a genny, one problem though it has a tappered crankshaft, example: Tecumseh crankshaft #35441A HM100 tapered shaft - eBay (item 330364519133 end time Oct-30-09 23:40:47 PDT) and i was wondering if i could just swap the crankshaft with this: John...
  16. D
    Brake help.
    Hi guys i have a mini bike im restoring and when i got the brakes out they were worn out so my uncle gave me another one but i cant seem to get them into the drum but even if i did get them in the drum they would get rub. im thinking about grinding down the shoes where they attach to the actaul...
  17. H
    Need help.
    Alright so I need a new clutch currently have a Max Torque and didnt ride on it much but was pretty good so will probally stay with Max Torque. Should I make sure to get a clutch with same teeth and chain size but what im wondering is how do I measure to see if its like 3/4" bore or 5/8".
  18. B
    15 yearold building dragster minibike and needs help.
    hi everybody my name is ryan and im new to this site. i just got in to building mini bikes and working with small engines. so far ive built one mini made from scrap pieces of metal, a broken bikes, and a 3 hp briggs flattie i overhauled, it is probably one of the ghettoest minis ever but it is...
  19. H
    Doodlebug acceleration help.
    Hey, can anyone help me with my doodlebug's acceleration? It is really bad. I already removed the governor and am getting good speed, though. Thanks.:hack::doah::hammer:
  20. D
    Who is our Golf Kart Pro? I need Help.
    I picked up a Yamaha G1 Golf Kart, a KE175 Dirt Bike, and a Schwinn Sting Ray bike for $50.00 yesterday. I tore down the Engine on the Golf cart and found that it has a broken Piston Skirt, and bad Rod Bearings. What I need to know is if my briggs 5 horse will be a adiquite replacement, or if it...
