Curious about others solutions to my issue.
A bike I recently got has bad tire rub against the upper spring cup on the front suspension. There are many ways to go here... but I'd rather not replace the tires.
Thanks
Hi, I have an unknown year Honda QA50E-3 005871
I need rings with my compression at 35 psi
The diamiter of my piston is 43 mm
Can someone tell me the year or part #
Any help would be great
white fenders with red tank and grey frame
I can find them till the cows come home in larger sizes ....
I want them for my Hilltopper ...
25mm / 1" I.D. on one end
20mm / .800" on the other end
80mm / 3" long (or a bit longer ...
Black preferred ....
Who might have them?
Thanks
Kevin
I need a replacement for my H25 that has a bad camshaft, crankshaft (both have stripped gears) and at least one stripped thread for holding the head on the block. I would prefer another H25 so I can swap all the new parts that i installed on the old one or a larger HP one that I can also swap...
picked it up out of the trash the carb is locked up and the bowl is coated with silicone, theres no tags on the engine. sprayed some starting fluid in the carb plugged in the elictric start and it fired rite up. the engine has an 3/4 shaft tapped and was chain drive with a clutch.
What size woodruff key is needed for the axle? My buddy just called me looking for some to put the drums on his Dunecycle axle...All I have is 5/32" x 3/4"... I don't know why I even have them. I've never used them.lol
I have a question maybe someone here can answer. The H50 I have has a drilled 1" PTO. I need to tap this for a TC mount-up job. Hole size is unknown but a 5/16 drill will fit with some wobble. I know that a 5/16-24 bolt is common for other shaft diameters but what is workable for the 1"...
So the Coleman ct200u runs 420 chains, problem is looking at rear sprockets with a high tooth count such as 72 or higher only come in #35. So I can change the chain no problem.....but what do you think about going from a 420 to a 35 chain?
It's a clone 6.5 motor with a torque converter 6"...
I know this is a long shot but would anyone happen to know what the thread size is of the oil filler hole on side covers. Also would anyone happen to have one or know where I could get one. Thanks Rick.
Can anyone tell me the dimensions of the two roller bearings that support the steering stem????? Mine are mangled beyond repair and I can't seem to come up with anything on Ebay that matches my measurements. Thanks.
