I have a 6.5 that I am going to build, I dropped the head off to get milled .065... My questions are, Will a flat top piston with the head milled be too much compression?? next question: which engine has teh flat top piston stock?? gxv160 mower engine or the gx160 horiz shaft eng??
I'll be getting a billet rod and either a billet flywheel or a gxv160 alum flywheel, most likely the billet.... I am also looking at a 265 lift cam... I'll probably be running a vm22 or 24mm mikuni, not sure on the carb yet, I have to get more info on that part, which one will work best?..
