Some progress today!
I started with a piece of 1/4 inch plate and machined the back side so that when the part is complete the back would have a nice finish for paint.
Into the vise with the good side down the inside is machined out and the mounting holes drilled.
I call it a fixture but it's just flat stock with 2 holes drilled and tapped. The part is bolted to it for machining.
The outside profile is then cut
On the same piece of material a second fixture is made. 2 holes and a pocket to clear the piece so the rear can be accessed.
Then some small cuts are made to fonish the back.
Still needs a few details but it's 95% done.
