Hello... Hoping someone here might know the answer and be able to help out... Just had my engine on my Coleman CT200U die off on me. Got a Predator 212 to put on it. But the drive shaft on the Predator is 3/4 inch while the drive shaft on the original Coleman engine is 5/8... I guess they built the very 1st ones with a 5/8 instead of 3/4... So I now need a new clutch that will fit the 3/4 drive shaft on the predator 212...
Now here is the confusing part... The original engine had a metal bushing between the clutch and the engine... Im now looking around for that part but 1 that would fit the 3/4 drive shaft on the predator212 and the only option anyone has seems to be the bushing used on the Baja MB200 models. Those seem to be 13mm wide tho and the bushing used on the original coleman engine isn't that wide... So the question is... Do you use a bushing between the clutch and engine when you put a Predator 212 onto a Coleman CT200U?? And if you do what part do you use and where can it be found? Im hoping someone out there has already done this before and will know the answer... Please help so I can get back up and going... Thanks...
