kit
  1. M
    New in the zoo
    I've been lurking on the site since before Christmas and am now ready to speak up and say hi. Last year my then 12 year old daughter wanted a motorized scooter for Christmas. We screwed up and got her an electric Razor stand-up scooter, she wanted a sit down scooter. , This year was time...
  2. John ONeal
    Bored GX 390 carb on GX 270
    I installed an NR racing stage II kit in my Honda GX 270 . It included a cam /springs 4 degree key, intake manifold, air filter, a bored 390 Gx carb plus Robertson H loop exhaust system. The carb is 23.5 mm bore a .037 main and a .025 pilot with a stock E tube . The kit installed easily and the...
  3. 8
    Clutch help
    Im looking to install my 212 and need some help. I read the post on the clutch brake and will be doing one with my own bracket and cover. I need to know what clutch should i get and why. Also do i need a spacer kit? I've seen clutches on ebay for 23.99, Max torque for around 33. and halliards...
  4. Txpowdercoater
    OldMiniBikes clutch brake install question
    I have called and they were closed so I thought I would ask those that have installed this kit. I ordered the cable they recommended at the page bottom but I cant see any way it will work with the kit. I was hoping someone could shed some light on the subject for me. Thanks so much! this is the...
  5. L
    FS parts from minibike kit
    I recently retired and had plans to fix an old mini-bike or two, But other things have pushed that plan out. :no: These are new un-used parts from an Anzus (?) kit. Brake hub, shoes, drum/sprocket, cable lever, throttle, cable return spring, etc. also about 12' of 420 chain and 4 master links...
  6. ZR9B
    point part # please Rupp 4 HP
    Only asking because the set I have ,the condenser mount is not the same and it is smaller, the part # I have is kit # 730523. this is going on a Rupp Hustler 4 HP. Thanks
  7. K
    Predator 212cc Mini Bike Kit - Stage 1 - Non-Hemi
    I found this at OldMiniBikes warehouse. Has anyone bought and installed one before. and is it worth buying. And can u run this kit with the governor installed or do I need to remove it before installing it. Please help
  8. jackeo21
    Briggs 5hp Restoration + Questions
    Hey all, I am restoring a 1974 5hp engine. The engine has not had very much use in its life, as there are faint remains of hone lines on the bore :laugh: I am doing this motor in its original white colours. I also plan to be using the stock flywheel. Which brings me to my point. I was...
  9. T
    Valve train trouble/ question on a predator 212 non Hemi
    Hey guys new here. I'm in the process of putting an engine together using the OldMiniBikes stage 4 kit. Everything is going fine until I went to put the head together provided in the kit. The valves from my existing head are loose in the OldMiniBikes provided head. I plan to call OldMiniBikes tomorrow and see what my...
  10. markus
    NOS Tecumseh mini bike throttle kit H50
    Complete NOS genuine mini bike throttle kit for the big block H engines :thumbsup: $58 shipped
  11. J
    Honda/clone Stage 4 engine kit ?s
    How much HP/torque doe the Stage 4 kit from OldMiniBikes warehouse add to the "200cc" Baka warrior engine? Can this kit be used on the Hemi Predator 212 cc engine? If so, how much HP/torque does it add to the Predator?
  12. sparkwizard
    420 too lean to start without choking it
    This is not one of my minithings. I put a Predator 420 on my son's yard tractor because he hated pulling the rope on the 212. {Merry Christmas} We have to choke it to start it even when it is warm, and if we raise the throttle too fast when it's in gear, it stalls. Is there a carb kit or a jet...
  13. J
    GEMINI SST80 Owners Manual Wanted
    Looking to purchase brochures, manuals and / or magazines containing tests on the Gemini SST80. Also looking for an original tool kit. Thanks
  14. toomanytoys
    heald documents any interest in scans?
    Haven't been around here for awhile. Top busy with work and in july me and my wife celebrated the birth of our son Cooper Now to the reason for this. Came across a ton of old heald papers at a flea market. Brochures warranty cards lighting kit instructions and other things. Lots of it is...
  15. 5
    I think this is pretty cool....
    I've wanted the engine to this for some time now, but they are quite rare. This kit might have something to do with the engine's short production run. 987190001 Subaru 7HP EX21 EFI Diagostic Software CD Cable Kit New | eBay
  16. T
    Getting started ?
    Hello,I just recently purchased an old Alexander Ronalds minibike. As a kid I was never allowed to have one.excepting the fact that I will never grow up and I have a little money I would like to do something really cool.so this is my first shot.I purchased a predator 212 Engine.I then went to a...
  17. B
    Hemi build for my 12 year old
    My 12 year old is going to start racing karts next year. I know he doesn't need anything wild. I have already taken the governor out so I will be adding a billet flywheel. But what are stuff should I change? I'm thinking springs for sure. I was looking at the stage 1 kit from the OldMiniBikes warehouse...
  18. D
    Looking for these 2 parts
    Looking for a complete live axel kit 1" shaft. Kit must be complete. Also I am looking for a keyed crankshaft for my Honda GX270. The motor I have in the box has a tapered shaft set up for a pump motor. If you have either of these and you live in the michigan area we can negotiate a price if you...
  19. J
    stretched ruttman drag frame
    hey whats up fellas i have a ruttman shortframe that was stretched 1ft with solid tubing, it has a jackshaft kit and a chain tensioner need gone takes up space in my garage 450obo... detroit michigan
  20. D
    Kit bikes
    Im going to get my son a kit for Christmas. I was looking at vintage bikes but im unsure how he would like an old wore out resto project under the tree for Christmas. Who has put the kits together, I am looking for feed back on the kits. Whats a good one? Good quality? How are the Azuza kits? I...
