Progre$$ working on mods & specs. Rear end all mocked up, fender brackets finished.
I bent two identical pcs. & welded them together. Got rear wheel set up now I know what I need spacer wise ( sprocket & brake )
Tweaked jack shaft mounts as the originals had been hacked and new ones welded on...
Front end is set up to my liking. The lowers were drilled out to 1/2" for 8" axle bolt that I got from OldMiniBikes witch isn't quite 8" & is a little sloppy in the 1/2" bearings I'll need to refigure that issue. I used a 1 1/2" spacer on top of fork bushing to set height of forks w/10" bolt So no threads in trees or bushings
witch I'll cut off after I fig. my fender bracket.
I removed kick stand bracket as the original wasn't going to work. So OldMiniBikes bracket & custom kick stand is coming.
Unforchanly as much as I was trying to avoid it I will have to lower rear shock mounts to get a nice stance. Sheesh! A lot more to come. I think I'm going with white frame, swing arm, jack shaft brackets, & band bracket. Black the front lowers & fade in black on front of frame. Any thoughts are more than welcome!
