gasket
  1. H
    Briggs head gasket
    Anyone know where I can get a copper head gasket locally. I'm in the LA area.
  2. FirePowerMinis
    Honda/Clone head gasket in MI, NOW!
    Found one.
  3. hotrodricky
    Clinton A400 Panther Gasket set
    Clinton A400 Panther Gasket & Seal set $25 with free shipping. Included: Pto Seal Point/side plate seal Carb gasket Air cleaner gasket Intake gasket Point/side plate gasket Exhaust gasket All the gaskets will work on 490 except the Pto seal
  4. C
    what gasket set for Briggs 3.75hp horizontal FH
    I got a nice, but not running Briggs 3.75hp FH off tiller. Engine model 94202 type 0115 E1 code 990113YB. Partstree gives pn 794209 for the gasket set, but when I look around to buy, its for a vertical shaft engine. Sears gives another pn 495605 that seems OK. Would like to buy from...
  5. P
    Clone 6.5 Carb "Gasket"
    As the title states I have a 6.5 Honda clone with a bad gasket on the carb float bowl. I can't find anywhere that sells just that gasket, do you have to buy a complete carb to get it? Can I pick these up at any autoparts store or am I going to have to fabricate one?
  6. vwfan79
    Carb-to-tank gasket leak
    I put a raptor carb on my briggs and every time I run it gas leaks out between the carb and the tank. The gasket is new and the screws are as tight as I can get them. Any suggestions on how to stop this? I was considering some RTV but wanted some second opinions before I did that.
  7. T
    Head Gasket Question
    I am a newbie I have a 5.5 160 clone in a mini baja I want to raise compression with a thinner head gasket if I get thinner metal one do I need to spray copper sealant on it before I use it?...Most I have found are .16 in thickness and I found one at smallenginecam.com a Burris coated gasket .09...
  8. B
    Will a bad fuel cap gasket cause failure?
    My 6.5 has been unreliable lately. Runs great for a minute or so and then just quits. It usually starts right back up but does it again. I took the carb off and found a tiny bit of junk in it, reassembled and it did fine for a day. Now I am back to the same thing. I think I read somewhere...
  9. C
    Predator head gasket
    Predator 212cc Ok first timer on the site. I just hopped a predator 212cc. Milled head to the max I think .065 or something. Flat top piston. Arc rod. Biggest cam they make think its the black mamba. 32 mm intake valve. Tilley carb on methanol. Billet flywheel. I blew the original head...
  10. G
    GX160 carb and head gasket questions
    I just got a used Honda GX160 I took the head off, and then put it back on reusing the gasket without torquing it I put a 6.5 predator clone carb on it, and got it started and idling If I give it any throttle it immediately it dies (choke open, if I close and give it choke it wont idle...
  11. Vintage_bike_nut
    Briggs head gasket
    hello, my 3.5 horse briggs is leaking out of the top end, and i need a new head gasket. if you have a new one or know where one is at, please let me know. i want to sell this bike and i want it fixed for the new owner. please and thank you Vintage_bike_nut
  12. G
    Carb Gasket needed for older Mini Baja with 5.5hp
    Hi, I'm having difficulty finding gasket part number 165-170 in stock anywhere. Would anyone know if the gasket ARCDJ-1320 at the following link is compatible? http://OldMiniBikes.com/images/P/dj-1320.jpg Thanks John
  13. A
    Side cover gasket on clone and torque
    I opened the crank case cover, did some governor work and had to replace the dry rotted original paper gasket. I tried the permatex gasket, the black type for oil. Now when i torque the bolts down the engine will barely turn over... i think maybe the original gasket was thicker than the permatex...
  14. 68chevelle
    Side cover gasket issues
    I have been running a modified clone motor in a race bike and keep blowing part 0f the gasket out of the side cover. Could this be an issue with crankcase venting? I am running maybe too small of a line out of the valve cover? or maybe the dowl's in the side cover are not allowing the proper...
  15. joekd
    Limp gasket
    Not a mini part but still the best product image More Information for FEL-PRO 35643
  16. ArcticMinibike
    Paper Gasket or Form-A-Gasket for Crankcase
    I am rebuilding a Sachs Saxonette 50cc 2 cycle engine for an Arctic Cat. I bought a complete NOS gasket and seal kit but after sitting on a shelf for 40 years, some of the larger, thiner gaskets have curled and twisted. If you are familiar with that engine, you know that there are 2 large but...
  17. wheels1950
    gasket for briggs head
    Is anyone familiar with a 3 1/2 briggs head gasket went to a shop to buy it today and the guy said there is a changeover number for the 3.5 it is a little different than the one i took off and looks like it might work possibly would a 3 and a 3.5 be the same Thanks FRANK
  18. C
    Predator 212cc head gasket question
    I have searched quite a bit and have gotten some conflicting information. Does anyone know if the GX200 head gasket will work on a Predator 212cc HF motor? If it is simply making the holes for dowel pins larger then to me that will work. Any help is appreciatted.
  19. joekd
    Help!!! Clone side cove gasket problems
    Ok here is the motor I need a side cover gasket for First I ordered this one from BMI which says it was for the clone and no more detail That one does not fit, everything fits correctly except the bolt hole in the bottom right corner I then ordered one for a GX200, it was...
  20. Bikerscum
    212 Predator head gasket source?
    The clone gaskets don't fit.... too small in the hole. I'd like to keep it thick... .030+ since I just milled the head .065. Any sources? Thanks!
