Anyone ever seen this before? This tank has a star stamped in the bottom. I've had a dozen of these in various sizes and formats, but I've never seen any with this stamp on them. I'm pretty sure the tank is NOS and the green paint is original (where's chipped, I can see clean bare metal...
It looks like a Powell Challenger with a modified rear suspension setup and Comet Torq-a-Verter. It also has front drum brakes like a Phantom 7? Foot rests are angled at the heel? Frame stamped 5025 E. Thanks for the help.:thumbsup:
Need to replace two pillow block bearings on my alsport trike.
It is 3 inches between bolt hole centers.
1 1/2 inches wide.
3 3/4 inches long.
Written on the top is Roberts SP-47
I have googled all over, and haven't found anything like it.
Found a few close, but nothing...
i have a stock valve train on my 6.5 clone i want to put 1.3 stamped rockers with 18 pound springs what do i have to do to make them work? i have searched i still dont understand them :helpsmilie: an i going to have to :grind:
OK, so this is a small thing, but which mail box do you drop 'em into? My buddy and I disagree on this. The envelope is metered, but one of us thinks the metered mailbox is for pre-sorts. We've each had a postal worker give us an opposite answer.
I want to trade an Azusa drum sprocket for a 72 tooth non drum sprocket that will fit a Tri-Star wheel with some spacing, I cant use the drum for my application I have a 60 or 72 I'll trade even. I dont have pics of both but here is the 72 (backing plate not included) I believe it's the 72. The...
I have a 2 yr old Tec OHH60 6 HP "Powersport" that has "166" stamped on the bottom of the float bowl nut. Can somebody tell me what that means?:confused: Is that the size of the main jet orifice?:confused: I have a high-flow K & N air filter installed on the carb. What size should the main jet...
New in box only bolted up never run cover is very nice and has only very minimal scratching from handling, comes with 20tooth 41 pitch sprocket only, use your clutch and get some sprockets and you're on your way! Will work better on a clone or tec. powersport as the briggs tanks cause you to...
